Heylooks great, now get that cleaned up and powdercoated and tell me where to send $$![]()
What are the clearances inside the case? Some people might want to use a 90 deg pci riser like in this thread
https://www.arcade-projects.com/forums/index.php?threads/compact-cps3.4257/post-60659
So a cover to the cartridge slot would be nice.
Are you making a mounting location for the different versions of the scsi2sd cards?
Looking forward to the Dreamcast case also.
When I finish the first 2 sample, I will open a pre-order for it.
There is a small Metal parts over under the pcb, and you will put your SCSI2SD pcb. The metal will support two different version of PCB. But first I have to find out the measurements.
Cartridge cover will include also
Please check the picture and you can see the place for SCSI2SD.
