Im working on it nowadays. But I will show it after all the cps3 cases are arrive to the buyers. I need feedbacks and test reports.Please show pictures of your CPS2 case if you decide to do one , im very interested![]()
Sorry for that. But I try to make it smaller. With the GD-rom it is impossible to make it smallerDang, these cases look great!
Too bad the dreamcast one doesn't have a cd door. Makes it hard to play the homebrew releases.
Keep it up man, you have amazing skill.
The next case is CPS-2 but maybe I will release ST-V too at the same timeST-V is what I'm waiting to see. Keep up the good work!![]()
There will be USB female mount on the back of the case (metal part) But I don't have any plan to create mounting point for 2.5" HDD in the case or out of the case.Hi!
regarding the Dreamcast cage... do you plan to have it with mounting points for a 2,5" HDD? (to use with USBGDROM)
are you basing your design off of the old USB GDROM with the external port?please check the Dreamcast pictures. You will see the USB female port for the USBGDROM
that would be vital for me, i've got the new revision which has an internal portare you basing your design off of the old USB GDROM with the external port?please check the Dreamcast pictures. You will see the USB female port for the USBGDROM
well, the internal one should still fit, but you'd have to disassemble the case every time you wanted to change the USB stick, and without enough room in the case for a HDD you wouldn't be able to use one at all if the port was blocked off.that would be vital for me, i've got the new revision which has an internal port
I will have a plan to put an extension USB cable between USBGDRom to Metal plate. Male to Female USB.(10-20cm )are you basing your design off of the old USB GDROM with the external port?please check the Dreamcast pictures. You will see the USB female port for the USBGDROM
Thanks for your supportBeautiful work with these. I just wrote this up for RetroRGB.com, hopefully it helps you reach your goal: http://retrorgb.com/metal-capcom-cps-3-arcade-case.html
I'm really interested in the Dreamcast case too![]()
I hope they will be ready to shipping, next week
