This solved a problem I was having with one of my CPS3 boards (no sync). One of the bodge wires had snapped off - now syncing! Thank you!Check on the bottom of the board, depending on the version you might have a little daughterboard (96682A-S) with an 74LS08 SOIC on it that's involved in sync generation.
I've seen mobos where this board is soldered directly to the 4 pins of the crystal on the top side of the mobo, and over time the pads on the daughterboard get lifted if it's not mounted flush.
Anyway, that would be a good place to start.
