Hi All, I have SF2 WW CPS1 board with major graphical issues.
What I have done so far:
Does anybody have any ideas of what to look at based on the above?
What I am thinking of doing but have questions:
Cheers!
- Swapped with working boards:
- my B+C boards with a known working A board has the same red scrambled graphics. (see pics)
- my A board with a known working B+C boards works with a weird vertical black line on left side (see pic "sf2 ww cps1_3.jpg")
- Verified all roms and eeproms against mame code.
- Reburned chips 29 and 36
- WIP: To test sockets: verified continuity between chip pins and pins on bottom of board. Chips 1,10,20 OK. Rest yet to be tested
- Checked continuity from C board's CPS-B-17 pins to interconnectors: OK
- One of the "CCX" Tantalum caps (10uf 10V) was rusted and snapped off, I replaced it with an electrolytic 10uf 16V
- 74LS chips: I have a logic probe which I never used, what is the best way to test them out?
- To order 74LS replacement, do the numbers matter: 74LSxxx, or can they be interchanged?
- PALs and GALs, can any chip with the same numbers be used as replacement or are they programmed?
Cheers!
