CPS1-Pi Multi Selector with OLED
BladeZX
Ontario Canada
Coming soon...
Will post more once I get my CPS1 multi and have tested the Rpi image
I have attached the gerber files
Here is a list of parts needed:
DescriptionQuantityPCB LocationDigikey Part No.Comment
GPIO Header for RPi11528-1969-NDthis mounts on the bottom of the pcb
Cap Cer 0.1uf 25V2C1,C2BC1154CT-ND
Res 220 OHM 1/4W 5%4R1,R2,R3,R4220QBK-ND
Switch Tactile SPST-NO 0.05A3EG1829-NDblack switches for up, down and select
Conn Rcpt USB2.0 TypeR 4POS1UE27AC54100-ND
Conn Header 14POS 2.54mm1
2057-PH2-14-UA-ND
connects to the CPS1 multi where the LCD panel connects - make sure pin 1 matches
OLED 128x641Amazon URL:
https://www.amazon.ca/Display-Modul...0.96+inch+oled+128x64&qid=1647185028&sprefix=
0+96+inch+oled+128x64%2Caps%2C52&sr=8-5
I recommend using a Raspberry Zero W
This is the case I am using for it:
You will also need a 8GB microSD card (I recommend Sandisk)
Here is the Raspberry Pi image you will need to load to the RPi. Just unzip it and load the img file using Win32DiskImager
CPS1-Pi Raspberry Pi Image ***** THIS LINK DOES NOT WORK YET
Note: If the link for the image does not work, copy the link and paste in a new window
The pi user is: pi
The pi password is: cps1multi
NOTE: The pcb connects directly to the 40pin GPIO pins on the RPi - make sure to match up pin 1
Connect a USB to microUSB cable from the multi selector to your RPi in order to power everything from one place
The first time you load it up, it will default to a hotspot with the name CPS1-Pi
Hotspot password is: cps1multi
Connect to the hotspot and then go to your browser on your phone and go to any web address (eg: gg.com)
The web interface should appear and you should see the games listed
You can also go to the Tools and select Wifi Configuration to join it to your home wifi network instead of using a hotspot.
You will be asked to select your wifi network and enter your password. You then need to click Apply and Reboot
This will reboot the RPi and it will connect to your home wifi if your credentials are correct.
Pure genius...
There is obviously also a lot of people who can't tolerate electromagnetic waves developped by wifi's system, and not everyone necessarily has a fashion-forward phone, an amplified desk telephone...
First generation phone user : me, for instance.
Hi
I begin to build oled selector for my multi. Cps1 multi rpi image will be ready?
Regards
Pure genius...
Wow, we're a retro arcade community and all, but 1st gen phone?!?! That's pretty baller!
There is a firmware update for the cps2 and cps1 that I need in order to continue testing
@Darksoft said he will let me know when it is ready
I am close but need to fix one issue that hopefully the firmware update will address
Great,
I order composants to finish my oled multi selector and Waiting for updates.
Regards
I progress. Pi zéro are out of stock everywhere 😔
Some news from @Darksoft , @BladeZX ?
I am stuck right now until the new LCD firmware is released
Darksoft is a busy guy - he said he would message me when he releases it
I can then finish up my testing and get this released
Hi @BladeZX,
Something new about your oled remotes CPS1/2?
Thank you
