CPS2 Battery adapter removal
ZeroGoukiX
Utica NY
So today I replaced the battery with an infinikey. That works no problem, my question though is how can I safely remove this battery adapter? I bought a SFZ3 board from Japan and the previous owner modded the board years ago to use a AA battery instead. It’s stuck to the board with a strong adhesive and I don’t want to risk damaging it by just trying to pull it out. Any suggestions?
I would try pulling it off. One side is off to the side, over the edge, just pry it up from there.
If it's really not budging, you could try sliding a utility knife blade in between provided it's stuck on with tape.
Or, you know, just leave it. It's inside the cart, who cares.
Yeah it’s not a big deal, I snipped the wires off anyway. I’ll try using a blade to scrape it off and if that doesn’t work I’ll just leave it.
