CPS2 battery voltage is low
kobayuz
japan
I repaired the suicide CPS 2. Although a new battery is installed, :D
However, the battery ran out again shortly after one week.
I bought the battery again. ||
We measured the voltage of the battery before connecting it to the board. The figure is 3.6V.
2.9 V when connected to the board. The figure is low. 8|
I replaced the electrolytic capacitor around the battery, but there is no change.
For what reason is the figure low?
I sometimes see substrates with similar symptoms, but can this be repaired? :D
What battery type are you using?
If the batteries have a recent manufacturing date and they are the correct type then maybe there is a short somewhere drawing more power from the battery.
Thank you for reply! :D
This is the battery
http://akizukidenshi.com/catalog/g/gB-03222/
I think that it is not a cause of battery life because it is brand new.
Connect the removed Maxell's battery (still 3.6 V) to the board again,
I will also try to measure the voltage. ;)
Is there a part that shorts and electricity flows more than necessary?
Is there a way to locate the location? 8o
