roy
Israel
hey
any chance there is an instruction some where on how to consolize cps2 A board?
thanks
roy
Israel
I saw that board and it looks great
but its not what I'm looking for
roy
Israel
instructions on how to fully consolize cps2 a board so I won't need to use supergun and pc power supply
xodaraP
Gold Coast, Australia
I'm not sure if there's instructions because it's one of those things that everyone will have a different idea on how they want it set up.
@undamned used to make a kit which made connecting things up easier but I'm not sure if he still makes these.
You still need a PC power supply but I think UD installed a PicoPSU into the case and it was powered from a laptop brick
roy
Israel
does the system needs 12v along 5v?
Fluffy
UK
Yes you need 12v for the sound circuit
I was wondering, has anyone ever designed a supergun that integrates a picopsu? Maybe scaled down to only generates the voltages/ampere that a board needs?
Can you generate the 12v from a boost converter, so you can support a wider range of input voltages?
xodaraP
@Frank_fjs runs his Supergun from a PicoPSU and it works fine
You probably could run +12 from a boost converter (I have done this on a Neo before I worked out how to mod for +5 only without cutting traces) but CPS2 and other boards, particularly Midway do draw quite a bit on +12 so it may be an issue.
Frank_fjs
Multi Boyz 4 Lyfe
Multi Boyz
Australia - Adelaide
Why use a DC booster for the 12V? The Pico supplies this natively. I use a voltage inverter to generate -5V from 12V.
Pico's work great, plenty of power for most boards.
Fluffy
UK
The idea would be to use a single-voltage power supply, maybe something relatively common like 9V, and only generate 12V and 5V. Picos generate 3.3V and -12V, which you wouldn't need for a supergun.
Frank_fjs
Multi Boyz 4 Lyfe
Multi Boyz
I don't see the harm in the superfluous voltages bring present. I mean, have you seen a Pico, held it in your hands? They're tiny! They only need a single DC barrel PSU to run too. Very handy little devices.
Fluffy
UK
Well, it isn't really harm, and it'll work fine... I just thought it is neater (and cheaper) to have a barrel jack and 2-3 voltage regulators directly on the board, than an ATX power connector and a separate picoPSU, especially when you want to consolize something.
Frank_fjs
Multi Boyz 4 Lyfe
Multi Boyz
I'm confused. Pico supplies both 5V and 12V, in a compact form and runs off a single PSU source. I feel it's neat enough. :)
DeWitt
Germany
I never heard of this PicoPSU! Nice little device! Thanks for the hint :)
GGPO_Halfro
Florida
So I have been working on this (in my spare time, work / school / kids lol), I did a little research because I wanted to do the project justice and I did not want to alter the original function of the board (keeping jamma edge etc). My project is:
Phoenixed Street Fighter Alpha 1 board
Darksoft CPS2 kit
CPS2 HDMI
Pico Power Supply
2 Undamned USB decoders
Fan Replacement (when I bought off ebay, they said fan was on verge of breaking so I just bought one outright)
Anyways, there really isnt a tutorial per-se but I did find this thread helpful:
https://shmups.system11.org/viewtopic.php?f=6&t=61912
It discusses some of things that are being discussed in here including power draw, etc.
This guy does it as a service (also shares lots of pics if you need a visual)
https://www.facebook.com/ifixretro
  • Like
Reactions: roy
GGPO_Halfro
Florida
No problem!
Honestly I would like to create a resource since I am still working on mine and it would be a good way to document the process to catch it from this point. I need to do the power supply next so I am going to do some research and then post the process + pictures. It doesnt seem that difficult just kinda annoying working with old plastic (the stand offs seem to break really easy on the pcb, I am so gentle with the board but maybe not enough lol).
