Did you try re-seating the C board too?all roms removed and re-seated, b board plugged directly into A board without case....nothing appears to make any difference..
no, makes no difference...Did you try re-seating the C board too?all roms removed and re-seated, b board plugged directly into A board without case....nothing appears to make any difference..
Does it get better if you press the boards together while it's running?
yes is a legit version, would prefer to sort it and use another game if Im honest with you.Is that a legit SSF2 Turbo board that you're going to sac for this?
I do agree, I've been trying to get a dead or phoenixed board for a while.......I'll get this one working first though mind you.Maybe post a WTT ad and see if someone has a suicided B board of a more common title that they'd trade for it. This won't help if the problem lies in the A board though.
thanks, but I have far to many boards to fix before taking on anymoreyou can have my acid burned B board if you feel like reversing the damage
Can you take a picture of the B board with the C board removed?what is that very top board for?? seems to work without it???Maybe post a WTT ad and see if someone has a suicided B board of a more common title that they'd trade for it. This won't help if the problem lies in the A board though.
yes its deffo the b board at fault, been tested on 2 different A boards and they both work with other games.Hmm it's possible that there is a broken trace somewhere that's responsible for that issue then.
Also, have you tested that A board with a different B board and confirmed there wasn't any issues? Or tested the SSF2T board on another A board?
