GoldenGlover
Looking to play 3S on a CPS3 kit and without using a CD? Do you also want a permanent battery free solution as close to original as you can get? Here’s a perfect plug & play solution for you:
Deciding to part with my spare CPS3 motherboard and SIMMS preloaded with Third Strike Revision A. The Third Strike cart pictured above is flashed with Darksoft’s NO CD Japan SuperBIOS which won’t display the Darksoft menu at boot up - you’ll be playing Japanese 3S Revision A right out of the gate every time (there is no region select or Darksoft screen at boot up). This will boot up just like a battery cartridge would. The included CPS3 cartridge is an original 3S Japanese region cart housing with original label. This is as close as you can get to having an OG 3S Japanese NoCD setup without ever worrying about a battery replacement. Motherboard, SIMMS and cart are also very clean.
You get the following:
Sold for $975 shipped.
- Third Strike cartridge flashed with No CD Japan SuperBIOS (to play 3S without a CD forever & instant boot up with no region select screen at startup).
- CPS3 motherboard - fully working audio, video and controls. No scratchy audio or SIMM errors here - everything is working flawlessly.
- Full set of original working CPS3 SIMMS (two 64 Mb SIMMS; four 128 MB SIMMS). SIMMS are Capcom originals no repros) and are labeled SIM 1 though SIM 6 as issued by Capcom.
