bartre
Hey all,
Recently got my hands on a 2nd CPS3 setup and i'm running into some hiccups.
So I got it all put together and the game itself runs fine (currently set to Jojo)
but I noticed something odd, I don't get the "now checking CD-ROM" page when I boot, it's just straight to the region select.
If I hold start on boot, I get to the expected darksoft menu where i should be able to program in a new game, but when i select it, regardless of what option I pick, it just boots the already programmed game.
I swapped the CD drive with the one I use in my known working setup and I get the same result.
If I swap the cart, but not the CD drive, it tells me the CD drive isn't connected properly, so I tried using my known working cables with no change
If i swap the cart and cd drive, I get the expected behavior where I can reprogram games, browse the CD files, etc.
I will note that the version of JoJo seems to be the No CD version regardless of region or anything that I select on boot.
My CD drive is an NEC CD-3010A, I've found a manual here- https://fccid.io/A3DCD-3010A/User-Manual/Users-Manual-17699
currently all jumpers are open, but when I first started, 1 & 3 were closed, is there a specific SCSI ID the CPS3 uses?
I'm wanting to upgrade to a SCSI2SD solution eventually anyway, so i'm not terribly concerned about the disc drive, but why wouldn't the cart check the CD drive even when I'm trying to program?
