SheepyChris
Hey y'all,
We've gotten around to start work on a CPS3 with a SFIII Third Strike cartridge at our arcade, the battery on the cart ran dry and the screen would either display nothing or a garbled pattern typical of that. We've removed the battery, desoldered the flash chip, installed Darksoft's UltraBIOS custom SH2 with CD, resoldered and there was no change to its behavior. We've done the following so far:
- Double checked orientation and solder on flash chip
- Reseated the cartridge and SIMMs several times alongside using isopropyl alcohol and contact cleaner on pins
- Reflowed and continuity tested every pin on the cartridge connector
- Reflowed pins on the GLL1, CCU and M514260B chips that looked tarnished/corroded
- All visible traces that looked suspicious of corrosion were tested, including resistor pack traces between CCU and M514260B
- Checked voltages, test cabinet was delivering 4.92v
The only things I haven't gone through yet are:
- Testing all vias near the cartridge port
- Replacing the 6.25MHz crystal oscillator on the cartridge - it has some severe surface corrosion as seen in the pictures
- Test the cart on another PCB (don't have access to a second one :p)
If there's anything we're missing any help would be much appreciated.
