Crediar Lindbergh Multiboot - Outrun 2 SDX HD - Sun Brightness Problem
ScHlAuChi
Germany
I recently aquired a Race Cab that was originally a ScudRace that was converted to Lindbergh with a flatscreen.
It already had the Crediar Multiboot 9.60 JVS installed to play all 7 racers supported by it.
Everything seems to work fine, except the best game Outrun 2 SDX HD has a sun brightness problem.
I know this problem also happend on Teknoparrot and was partly fixed there - but is there a fix for the Lindbergh version too?
As it makes some areas of tracks impossible to play as the whole screen whites out.
*edit* This does not happen with the normal, Lowres version! *edit*
So it seems Teknoparrot has a Nvidia Shader Fix that does solve this problem:
But the question then is, would it be possible to do the Shaderfix on the original version too?
I did manage to copy the content off the Lindy Multi HD over to the PC and now have a file like or2.dat
What are the tools to decrypt/unpack those files to get access to the original files?
And once the mod is applied, can those be encrypted again afterwards so they still work on the Lindy?
Seeing that the Multi also has a version called "Outrun 2 SDX HD Gangsta Edition" with terrible RAP music, means it must be possible somehow!
Does anyone here have the knowledge how that is done?
Years ago, I have made a working version music replacement with The Prodigy The Fat of the Land in Teknoparrot for Outrun 2 SDX Gangsta Edition.
I was not able to unpack or decrypt the .dat files with different Windows tools and no response on another website forums but if someone has information here, I would be interested too.
Music files are .adx located in Jennifer\data with decrypted or2 games. For example, here are my filelist :
01Breathe.txt
01splash_wave.adx
02Narayan.txt
02magical_sound_shower.adx
03Mindfield.txt
03passing_breeze.adx
04Smack my bitch up.txt
04risky_ride1.adx
05Serial Thrilla.txt
05shiny_world.adx
06Firestarter.txt
06night_flight.adx
06night_flight_old.adx
07Climbalize.txt
07life_was_a_bore.adx
sel_01splash_w.adx
sel_02magical_s.adx
sel_03passing_b.adx
sel_04risky_r.adx
sel_05shiny_w.adx
sel_06night_f.adx
sel_07life_was.adx
01* files are for ingame music
and sel* are for music for the selection menu.
01Breathe.txt
01splash_wave.adx
02Narayan.txt
03Mindfield.txt
04risky_ride1.adx
05shiny_world.adx
06Firestarter.txt
06night_flight.adx
07Climbalize.txt
sel_01splash_w.adx
sel_02magical_s.adx
sel_03passing_b.adx
sel_04risky_r.adx
sel_05shiny_w.adx
sel_06night_f.adx
sel_07life_was.adx
Now how did you change the music exactly on the multi version?
I have a version i made with mostly songs from other Sega racers and if i can just swap the gangsta version with my version, it would be neat.
I only made a version with decrypted files and use it in Teknoparrot to verify it was working.
Does anyone has a solution to build .dat from decrypted files to copy to disk of the multi ?
Anyway, Outrun2 has a terrible bug in the multi: wheel disabled after a 30minutes of play. This was never fixed as far as i recall, so the sun brightness problem is really a minor issue.🤢
Hi there guys,
Since I also have this issue...is there a solution for that now ?
