Custom Virtual-On panel ( Oct. 15th 2022 updated )
alberto1225
Taiwan
Update some twin stick information (Oc.15.2022)
There are more and more choice for twin stick nowadays.
Panel mount I can make for these twin sticks
  • Sanwa twin stick (same or better quality than arcade twin sticks)
http://www.sanwa-d.shop/shopdetail/000000000066/all_items/page1/order/
  • Arcade twin stick# JLV2-G2-FO
  • Tanita twin stick # JLV-T2B
http://www.sanwa-d.shop/shopdetail/000000000029/ct24/page1/order/
  • Xbox 360: Hori Twin stick EX force version
  • Sega Saturn / Dreamcast twin stick
  • Amazon 8 way Flight joystick with trihher and top fire button (@notsonic confirms )
https://www.amazon.com/gp/product/B07YSP34J9/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Installing a pair of SANWA JLV2-GF2-F0
Simple to install, remove lock washer and pull out spring. Just be careful when removing the Stick as it's greased up with a small ping to secure it.
And I also ask is it possible to replace the bulky Happ sticks in U.S. Virtual On cabs with those Sanwa sticks too.
Hi! Any chance you’d be open to sharing the source for that instruction card?
Or if anyone reading knows where I can find VOOT art or scans, I would appreciate it.
I can try scanning when i get a chance. I sourced this through Alberto when receiving the sticks and panel.
Other than the twin sticks and the custom panel, are there any other major roadblocks to running Virtual On in two cabinets already running a naomi multi?
You'll need two naomi's. each unit leverages P1+P2 controls for each stick respectively.
If anyone has the amazon sticks in the top link and would like something more original, I designed a 3D printed sleeve to go over the shaft and mate with these handles:
https://www.aliexpress.com/item/1005006461724009.html?gps-id=pcDetailTopMoreOtherSeller&_t=gps-id:pcDetailTopMoreOtherSeller,scm-url:1007.40050.354490.0,pvid:442d872b-8f62-46b1-b818-596b789a8729,tpp_buckets:668#2846#8112#1997&pdp_ext_f={"order":"389","spu_best_type":"price","eval":"1","sceneId":"30050","fromPage":"recommend"}
here's a link to the model:
https://cad.onshape.com/documents/c...renderMode=0&uiState=6adb5bdd3b24c18117f82ece
it will accept 4 m5 nuts and the screw from the original joystick to the shaft to prevent rotation. You'll also need to buy 8 6mm m5 allen bolts, and you'll need to wire the triggers up. Hope that helps!
