Cyber Lead PSU Replacement
notsonic
NJ
The original power supply in my Cyber Lead was going bad. It was causing audio interference (static) and video interference (horizontal lines, unstable picture), as well as making a sizzling noise. It might be repairable but I figured a replacement was best.
Parts:
  • 18 Gauge Wire
  • Size 6? Red Fork Terminals x7
  • Size 6? Blue Fork Terminals x2
  • 0039013063 - Molex Mini Fit Jr Female 6 position x1
  • 0039013083 - Molex Mini Fit Jr Female 8 position x1
  • 0039000040 - Molex Mini Fit Jr Pins x12
  • MHS012 - Mean Well PSU Feet
  • QP-150-3A - Mean Well PSU
  • M4 Nutserts x4
  • M4 Screws x4
I started by removing the stock power supply. Then I marked and drilled 4 holes for the Mean Well PSU and installed nutserts. You could just use a nut but I had nutserts I wanted to try out.
Next I cut the stock AC connector off. AFAIK there's no good wire to wire female end for this type of connector. (Something I didn't do but suggest is installing a 3 pin connector between the fork terminals and the AC wiring. You can't access the screw terminals once the PSU is mounted and it's a little annoying to have to pull the PSU screws to disconnect the AC lines.)
AC Wiring:
  • Green - FG
  • White - L/Live/Hot (yes, white is hot)
  • Gray - N/Neutral
To make the dc harness just match what's already there. I recommend using blue fork terminals to connect the grounds together on the PSU side since there's 7 of them to try to shove into the 2 terminals on the PSU. I doubled up red forks since it's all I had and it's not that clean.
DC Wiring:
  • Red - +5
  • Brown - +3.3 (I used purple)
  • Yellow - +12
  • Black - Ground/Com
This same psu is in some of the early windy 2s. I wonder if I could retrofit the case for something like this.
