Darcksoft CPS1 Multi Case
LittleMegaGamer
Ireland
Happy new year guys.
Finally, I got some time during the Christmas break to work on the CPS1 Multi.
I made a case for the CPS1 Multi following the same design used for my craft cases in perplex already shown in previous threads.
Whoever would like to make one needs
1) two A3 sheets in Perplex/Plexiglas (5mm Thickness)
2) cut the long side of both sheets to fit the Multi and join them by using spacers of min height of 75mm
3) secure the A board to the bottom panel and install on top the Multi board with any accessories
4) secure the Multi board to the top panel
5) Screw fix the top panel with the bottom one.
I have installed the remote dip switch which is very handy in this case.
I got the Dual Crystal but I will probably leave this board with the original 12mhz for now...
Hopefully I will get the time to make a video with more photos and details
My next project will be to install a good Jamma switcher to my NAC. I am open to any suggestions.
Looks awesome, also like the way you have utilised the space inside the cab with extra ply wood. might have to steal that idea for myself ;)
I use the 6 way and my brother use the 2 way, perfect in your NAC for multi CPS1 and CPS2:
https://riddledtv.com/jamma_switchers.html
and I use this jamma extension
A strong power supply required.
You got a great setup there.
I would like to connect more boards in pile but I have limited space at the moment…
I think I will go for the 2way switcher basic model. That looks the most appropriate for my cab. Do you think the original PSU is enough for it? I wouldn’t change it otherwise.
My brother use the 2 way in his AC, and I thinks you will succes install the CPS1 and CPS2 multi in your NAC. About the power supply, test in a first time with original and check 5V. For 2 way I assume that it could be sufficient.
