Just got my Darksoft CPS2 unit set up with a HAS supergun. First issue, no audio. Relatively small issue I can look more into later. Haven't tried the RCA plugs on the CPS2 A board yet either.
The real issue is though, sometimes games slow to a crawl. They'll usually boot fine but then after a minute or so on slow to less than 1 frame per second. I've downloaded the suicidetesterv2multikit test and it's reporting low values for the speed test. They say that upping the voltage may help, but according to the voltmeter on the HAS I'm running it at 5.00V give or take .02V at times. I've read elsewhere that you can run it at a max of 5.10V but I'm afraid to up the voltage on my first arcade system.
I have a multimeter I could probe around the A/B boards themselves with but I'm not sure where to check. I've heard that can give more accurate voltage readings than what's on the HAS.
Thanks for any help!
-Edit-
MVC Revision 7/Pal G B board.
I'm using the old rom set as I don't have the key writer installed yet. Not sure if that makes a difference.
-Edit-
