GoldenGlover
Looking to play any CPS3 title in USA region on a CPS3 kit and without using a CD or SCSI emulator? Want to also be able to change your CPS3 game & still never use a CD or SCSI emulator once it’s loaded?
Here’s a perfect plug & play solution for you:
This CPS3 kit here is preloaded with Third Strike Revision A. The SuperBIOS cart pictured above is flashed with Darksoft’s NO CD USA SuperBIOS (Custom SH2) which won’t display the Darksoft menu at boot up - you’ll be playing USA 3S Revision A right out of the gate every time (there is no region selector Darksoft screen at boot up).
This is as effortless as setup as you’ll ever get with regard to playing CPS3 without a CD or SCSI emulator hooked up. Should you ever want to load a new game, just remove the SuperBIOS cart & insert the UltraBIOS CD cart pictured with the provided CDROM drive or your SCSI emulator of choice.
You’ll get the following:
Positive feedback for me can be found throughout these forums. I ship fast within one business day of receiving payment & also provide you with tracking photos and a tracking number prior to shipping. Everything shown here will be *properly* packed and arrive to you in the same working condition it’s leaving me.
Sold (without CD drive and cables pictured) for $1,200 shipped.
- UltraBIOS CD cart (Custom SH2) in original CPS3 cartridge housing & label by @djsheep. This cart will allow you to change and load games whenever you decide to use it & is fully compatible with both regular CPS3 SIMMS and UltraSIMMS.
- Original CPS3 cartridge housing with a SuperBIOS label by @djsheep & flashed with Darksoft’s NoCD USA SuperBIOS (to play any loaded game without a CD or SCSI emulator forever & instant boot up with no region select screen at startup).
- CPS3 motherboard - fully working audio, video and controls. No scratchy audio or SIMM errors here - everything is working flawlessly. Super clean motherboard with no repairs; the cart slot and all connectors have also been properly cleaned with Deoxit to ensure your SIMMS and cart will work without issue.
- Hursit CPS3 case in silver color with working blue LED light & molex power connector. Case has some normal wear & tear; nothing too out of the ordinary. I’m also including the SCSI plate and screws these cases came with (I removed it given this is being used as a NoCD setup).
- Full set of working CPS3 SIMMS (two 64 Mb SIMMS; four 128 MB SIMMS). 4 of the six SIMMS (two 64 MB & two 128 MB) are Capcom originals, with two of the remaining 128 MB SIMMS located in slots 3 and 5 being 1:1 Fujitsu reproductions.
