Darksoft Multi no sound, Qsound ram check failed. Passes with real roms in 1 and 2
syntax_X
Australia
I have a cps2 multi kit here that had its sound die out then later fails on Qsound ram checks.
Its not the A or B board, both have been swapped and the problem follows the multi kit.
I found that the Qsound ram issue can be from poorly seated 1 2 roms, which the multi has no pin connections to it seems.
I put roms in 1 and 2 from my Vsav board and loaded Vsav with the multi and it works! Passes the Qsound ram check for that game, but still no sound.
So my one and only question is, what part/s do I replace on the multi that would stop communication of rom 1 and 2 and sound?
UPDATE
I removed the first 8 sn74lvc4245a from the kit and its running the same.
Guessing its them or something else further down the line?
I too have this current issue with my multi kit.
Hopefully bumming this to get another look for others.
Thanks in advance.
Has anyone else had this occurrence where the cps2 multi passes all ram check except the q sound? I too have swatted out A boards while test and receive the same results.
Any leads or insight how to diagnose would be great. Thanks in advance.
