Let me get that please :)
Could you please forward me your list as well?
Here it's, let me know if I've missed something :)
2020bb
3countb
alpham2
androdun
aodk
aof
aof2
aof3
b2b
bakatono
bangbead
bjourney
blazstar
breakers
breakrev
bstars
bstars2
burningf
crswd2bl
crsword
ctomaday
cyberlip
diggerma
doubledr
dragonsh
eightman
fatfursp
fatfury1
fatfury2
fatfury3
fbfrenzy
fightfev
flipshot
froman2b
fswords
galaxyfg
ganryu
garou
ghostlop
goalx3
gowcaizr
gpilots
gururin
ironclad
irrmaze
janshin
joyjoy
kabukikl
karnovr
kizuna
kof2000
kof2001
kof2002
kof2003
kof94
kof95
kof96
kof97
kof98
kof99
kotm
kotm2
lans2004
lastblad
lastbld2
lbowling
legendos
lresort
magdrop2
magdrop3
maglord
mahretsu
marukodq
matrim
Menu
miexchng
minasan
moshougi
mslug
mslug2
mslug3
mslug4
mslug5
mslugx
mutnat
nam1975
ncombat
ncommand
neobombe
neocup98
neodrift
neomrdo
ninjamas
nitd
overtop
panicbom
pbobbl2n
pbobblen
pgoal
pnyaa
popbounc
preisle2
pspikes2
pulstar
puzzldpr
puzzledp
quizdai2
quizdais
quizkof
ragnagrd
rbff1
rbff2
rbffspec
ridhero
roboarmy
rotd
s1945p
samsh5sp
samsho
samsho2
samsho3
samsho4
samsho5
savagere
sbp
sdodgeb
sengoku
sengoku2
sengoku3
shocktr2
shocktro
socbrawl
sonicwi2
sonicwi3
spinmast
ssideki
ssideki2
ssideki3
ssideki4
stakwin
stakwin2
strhoop
superspy
svc
tophuntr
totc
tpgolf
tphuntrh
trally
turfmast
twinspri
tws96
viewpoin
vliner
wakuwak7
wh1
wh2
wh2j
whp
wjammers
zedblade
zintrckb
zupapa
Yes no other problems except for the moving pixels.
I have no other problems, but pixels don't move however... They are always in the same areas/positions, even when comparing two different 1FZ motherboards.
@Derick2k
Your 1FZ works fine with the shipped version multi, can I ask - has your Neo board been recapped recently/while in your possession? If so, what brand caps were used?
@jassin000
@waiwainl
... And others with 1FZ boards
Can you confirm if your boards have ever been recapped? And if so, with what brand?
Both of my 1FZ's have original caps, you can tell by the ancient layer of hot glue SNK added over the top of them. X/
Thing is I don't believe this has anything to do with it... If it did, why did the beta cart work perfectly (also other games/carts work perfectly)?
My big red 4 slot has flickering little glitch horizontal lines, and it's been fully recapped.
For multi slots there are (still) known graphical glitches, as mentioned before.
Are these listed somewhere, because I can't find any description of what is known to be an issue anywhere, just "4 and 6 slots are problematic, try not using one" a bunch of times.
My 4-slots don't seem to exhibit any sort of graphical glitches on the 20 or so games I've played around with, or the menu, and I get more and more curious every time someone says the bigger multi-slots have issues..
It'd be really nice if we could get an official list of "confirmed issues that are being worked on". or even a list of "expected behavior" that differs from factory like the garbled multi-bios logo on first boot.
without this people are continually reporting already known issues and making it seem much worse than it is IMO.
I maintained a shared Google Doc with Darksoft to communicate testing issues and bug discovery.
I do not want to make this document public however, as it was started two menu versions ago when I first received the beta cart.
Some of my reported errors are no longer applicable after update, and I didn't have time to perform a proper re-retest to revise every entry.
If you could see my list it makes it seem much worse than it actually is (and it's not accurate). ;)
@Derick2k
@jassin000
@waiwainl
Original caps Im afraid, I should recap it though, specially the audio section. Anyone have cap list/kit?
Post a pic, is it in the menu when you are moving thru menu items??
But yeah, multi slots have a few glitches still, that will be worked out soon.
Should there be sub sections to this help thread or to the MVS multi support section for the single slot & multi slot mobos, just to keep things a little more tidy?
Hey DarkSoft just a quick update Incase this might help you figure anything out. Again I’m using a mv-1fs with uni v3.3. All voltages measured on the jamma edge.
Slot#1 baseball stars 2
Slot#2 blazing star
Slot#3 ironclad
5.00V
Multi menu started and I waited for slot 1 to load. Baseball stars 2 loads and I played for about 5 minutes. Tried to switch to next game no response. Tried to return to menu and no response. Then do a soft reboot through the unibios. While it’s rebooting I switch to slot two. Gives error and goes into boot loop. Turn off (psu) and get a hanging please wait checking filesystem...
4.56V
Games are working fine, slot switch and menu return controls both work.
Ok, so my multi cart seems to be working 100% as far as functionality goes. I havent been looking for in-game stuff, yet.
The only thing I have noticed so far has been that on a cold boot the Neo Geo logo on the unibios splash screen is corrupted, when changing slots the logo appears fine.
Taking requests for things to check for. What are the 3 largest games to load? I want see how long it will take to flash them 1st time around into the slots, and then how long it will it take to load them afterwards on a cold boot.
Ill try to take pics/video.
My setup for testing:
MV-1FZ (Unibios 3.3) unmodified in any other way oem mobo
5.00v at the jamma edge, I used 4.56-5.16 and it didnt make a difference cart still worked the same.
Vewlix Cab with Taito Jamma Kit
I'm not encountering any of the hangs or graphic glitches. But the shortcuts to switch slots or return to the Menu do not work on my Egret 2 and MV-1B. Up + Start or Right + Start, no worky.
Guess I'll play with my 5v, as I have it at 5.10 at the Jamma edge currently.
Just to add to the info list, on my MV-1F I also have the SNK-glue over my caps. Also have Pixel errors.
@jassin000
@waiwainl
Original caps. Not sure what brand; here is the hiress picture (click on it)
