no ! contra and otomedius don't work.Do you have Contra on the Taito Type X2?
Wait, you can put Contra on X2!?no ! contra and otomedius don't work.Do you have Contra on the Taito Type X2?
i dont know if i have 1gb or less ? how i check ?
This is how you check.Have you tried physically looking at the RAM to see how much you have?
hello , can you send me a link for dowload your version of otomedius ? please .Otomedius works for me...
I didn't download anything =/. I bought a HDD from Darksoft back when the CPS2 kits first hit and he'd mentioned some stock in an email.hello , can you send me a link for dowload your version of otomedius ? please .Otomedius works for me...
i have check the ram , i have only 512 MB
regards
I don't know. I'm no hacker. lol It's cool that you can run it on x2 though, right?Random side question. The actual Cave Deathsmiles II hardware came with a 2GB DDR2 800 stick of ram installed. I know the Taito Type-X2 version isn't totally arcade accurate (i.e. the slowdown), but why the Type-X2 version need only 1GB of ram to run the game?
It runs fine with the Tatio JVS I/O.About Deathsmiles on TX2, is it using some kind of JVS to Keyboard program or does it run natively with the Taito Type I/O card?
No. It requires far too much extra hardware (2 Taito ethernet "fast" JVS IO's, a special PCI slot card, 2 monitors (no 1 monitor option for X2)). You're better off buying it on Steam and running a PC or Steam Link in your cabinet. You could have a whole Steam Link setup for less than what one of those IO's would run you (if you could find one).any chance we get dariusburst in a form we can manually add it to the multi?
1.) To answer the original question, its doesn't natively support JVS.It runs fine with the Tatio JVS I/O.About Deathsmiles on TX2, is it using some kind of JVS to Keyboard program or does it run natively with the Taito Type I/O card?No. It requires far too much extra hardware (2 Taito ethernet "fast" JVS IO's, a special PCI slot card, 2 monitors (no 1 monitor option for X2)). You're better off buying it on Steam and running a PC or Steam Link in your cabinet. You could have a whole Steam Link setup for less than what one of those IO's would run you (if you could find one).any chance we get dariusburst in a form we can manually add it to the multi?
The Steam version also has the entire arcade version untouched within it.
