I wanted to stay away from commenting due to potential flaming, but I couldn't help myself.
Professional pcb cleaning is done with an industrial dishwasher-like device, and a special cleaner.
Don't take my word for it, here's just one example by CERN:
https://www.electronicsweekly.com/news/business/manufacturing/cerns-alternative-pcb-washer-2014-12/
Final rinse is done with... guess what? Plain old water.Though obviously Deionized water is the better choice if you have hard water in your area.
From what I see, there are only two potential problems with a household dishwasher.
First, is that nasties from the board and cleaning agents will get mixed into the dishwasher that you use for things that touch food. This is not great for obvious reasons, even though theoretically the wash should be sufficient to wash them all away.
Second, a household dishwasher uses fairly low impact water. This may not be sufficient for the water to work it's way under bga and larger smd components, leaving contaminants under components which can mix with water and cause corrosion..
I have personally been washing electronics and PCBs for a long time now with a process that involves an IPA wash/scrub, followed by a hot water rinse, followed by a scrub with a cleaner that has a saponifier of some sort in it, then another hot water rinse before an immediate final thorough drying using heat.. Never had any issues, and the boards come out looking great. Inspection with my inspection microscope shows nothing to suggest that my process is damaging or induces/accelerates corrosion.
I am of the opinion that leaving contaminants on a board is more likely to induce or accelerate corrosion than washing the board clean of corrosive dirt/dust/residues.
Basically it boils down to this IMO:
1. A household dishwasher is ok, and will not damage your boards, but it may not be the right tool and may not sufficiently clean. Your mileage may vary.
2. There is nothing wrong with water rinses as long as there is sufficient impact/pressure to reach under components.
3. Always use some sort of cleaning agents, this can be IPA, a combination of your choice, or a dedicated PCB cleaning product.
4. Thorough drying is key. If you don't have a good setup to facilitate drying, don't bother with washing.
Feel free to disagree.
