Following this, cause Jong.
Also, I have some spare button caps (the small ones) if you eventually need them and this spicy MVS conversion of Final Romance 2
Its a poor conversion without cdda audio track.Didn't know anyone did a MVS conversion. Think I have FR2 on NGC, but not sure how to go about testing the mahjong controller on AES or NGC systems.. I do have a SD Loader modded unit around here in one of the piles, wonder if there's homebrew that could test it (or if I could develop such).
My current effort is going to be making an adapter, pulling the missing pins from the side connector on a MV1C (or 1B) and seeing if I can inject that into the DB15 port of a supergun using a DB15 male to female breakout board.
That tracks, still might pick up a copy if I stumble upon one.Its a poor conversion without cdda audio track.
Does it connect OUT3 to Select?(still no idea what the AES/MVS switch on this weird controller does)
Not that I could tell, but I'll keep seeing if I can probe around on it.Does it connect OUT3 to Select?
Confirmed via multimeter, when in AES mode OUT3 is bound to SELECT. Nifty.Does it connect OUT3 to Select?
Yeah, I think the original mahjong controllers are going for around $1,200 USD. I think if I had one I would have gotten frustrated with it not working with a supergun, @pierpa86 was able to point me in the right direction to build the above adapter to pull in the three missing pins. Now I'm just struggling to remember how to use kicad to build out the PCB for the famicom controller.Looks like an awesome project. I still lament getting rid of my Neo Geo mahjong controller, and for way too cheap. They're prohibitively expensive now.
Well they're just exposed traces for the carbon pads to contact. EasyEDA has a good template for it, but I'm still struggling with KiCAD. It's just been too long since I last used it and I don't remember anything. May have to do a refresher tutorial when I have time...I think the difficult bit will be drawing the footprints for the buttons.
I've not done much more after getting the weird controller I found working. Just too many projects and not enough time on my end...Was just wondering if anyone got the Capcom controller working with Mahjong arcade boards?
I knocked up a quick breadboard a month or two ago, using it to control Poker Ladies, but as that's poker uses way less buttons.
I'm going to try and knock something up over the week to work with all the buttons, thinking of tying it into a ESP32 with a we server running as well so either the Capcom NES controller can be used or an iPad.
