Do RunRun graphic problem
Pflaugi
Germany, Meckesheim
Hello,
there are graphics problems with my Do RunRun.
I checked out the board. Noticeable are a SN74LS74AN and a SN74LS161AN.
With the SN74LS74AN there were 5 volts at PIN 14 normally, but at PIN 2 I have 0 volts and at PIN 3 only 0.05 volts ... I don't think so much ... The values are constant.
The SN74LS161AN has constant 0 volts on PIN 3 and 4 ...
I'm a beginner in board repairs. Could it be that these two ICs are defective?
I was wrong. when I see that, PIN 3 and 4 on the SN74LS161AN are on GND. Sure that they then have 0 volts.
on the SN74LS74AN PIN 2 is also on GND ... but the 0.05 volts at PIN3 make me wonder ...
Does somebody has any idea?
Do RunRun is working again!
the bit from E6 pin14 floated at 2.5V. So I changed the 4164 IC from E6.
D6 was wrongly unsoldered by me. But that was okay. I put it on a socket and built it back.
Many thanks to the Arcade friends who helped with the repair.
Reactions: nem
