Experimental - 3D printed shell for S18 Multi (BladeZX Arduino)
hatmoose
Enlightened
New Zealand
This is my first draft of a 3D printed shell for the awesome S18 Multi that @BladeZX has released over here
https://www.arcade-projects.com/threads/sega18-oled-selector.25479/page-3#post-384305
There are two versions of the S18 multi - an Arduino based version and a Raspberry PiZero version - this is for the Arduino version
Important note, this version of the case is not finished, may not fit, and has many mesh/skin errors, if you want to use it as the foundation for your own case feel free - but it's not yet a finished printable product
Screen Shot 2023-05-23 at 5.08.58 PM.pngScreen Shot 2023-05-23 at 5.08.30 PM.png
This one should be better. Still some model errors but all the bits fit, holes line up and etc - STL attached
I had to make the button holes a bit bigger so that my fat fingers could actually push the buttons - might see if I can find a part with a longer actuator.
Designed to bolt together with
4 x M3 20mm Hexagon socket head bolts, thread needs to be 20mm
https://www.aliexpress.com/item/4000784829771.html
4 x M3 Hexagon nuts
https://www.aliexpress.com/item/4000602853448.html
25mm bolts might actually be a better choice, but I didn't have any of those...
Screen Shot 2023-05-28 at 1.18.58 PM.pngScreen Shot 2023-05-28 at 1.19.18 PM.png
Success! I was hoping to have these print without supports, but because of the big overhang at the front I couldn't get that to work.
The shell is in two parts, the top half of the device fits into the top half of the shell, the bottom part fits into the bottom half.
Designed to bolt together with these if you want it to look nice
4 x M3 Hexagon nuts
Old version - overhang uncovered
Current version - overhang covered
Supports are kind of a pain with this design because by default they plug up the holes for the bolts and nuts. Luckily Cura to the rescue - when you generate supports you can set the minimum surface area that it will generate supports for - to avoid plugging up the bolt holes set it to 20mm or something larger.
So I'm going to call this "good" for now. Any requests for changes and etc please let me know
NICE!
Some questions/suggestions, and please don't exert yourself with any of this. It's good the way it is.
1. Is it possible to fill out the area of the underhang where there isn't a cable?
2. Also where the 4 screw points are, is it possible to fill out that whole area so the selector ends up as a solid cube/rectangle brick when fully assembled?
#1 easy, done!
#2 not so easy - need to re-arrange the PCB to move some of the elements around, drill some holes and generally adjust "stuff" in order for that to happen. I might ask BladeZX about a rev 1.2 at some stage
Alternatively you can drop some support blockers where the holes are
How could a guy get 3 of these cases made? Is there a service that would be able to take the file and make them locally? Great work hatmoose!
JLCPCB, in addition to being absolutely awesome for PCBs, now do 3D printing. I’ve never used their FDM service, but the resin and metal 3D print services are really impressive
A kind forum member has pointed out that if the DIP chips are socketed the top shell will not fit (about 3mm too short).
If I were using a parametric modeller like Freecad or Blender (blender does basic CAD!) or F360 this would be a one character change.
But my unfortunate addiction to Sketchup means a little more work. I’ll post an alternative version for socketed DIPs shortly.
TL;DR if you socket your DIP chips the top shell don’t fit.
