Can you snap a picture of your PCB for us in hi-res please ?Are there any particular pins you would recommend beeping out or do they all want doing? I'm just asking as there are 384 of them and I think I'm going to go cross eyed as they're quite tricky to probe![]()
CONSOLE CONNECTOR C CONSOLE CONNECTOR A
J3 J1
C1 B1 A1 C1 B1 A1
C2 B2 A2 C2 B2 A2
C3 B3 A3 C3 B3 A3
C32 B32 A32 C32 B32 A32
CONSOLE CONNECTOR D CONSOLE CONNECTOR B
J4 J2
C1 B1 A1 C1 B1 A1
C2 B2 A2 C2 B2 A2
C3 B3 A3 C3 B3 A3
Do you mean a visual check or continuity checks between the multi connector C and the IC legs? If it's the latter I'm going to need a pin out...You should check connector C and the following level shifters that go to it:
U9,U10,U11, U12,U13, U14, U16,U17,U18,U19,U20,U21.
I've just had some free time though and I've finished beeping out continuity between the C connector and every leg of the ICs that the schematics show are connected to them. The IC legs are pretty fine so I used a needle to make sure I was probing the leg in question and not bridging other legs.Connector A+B is Program Rom
Connector B is Ensoniq
Connector C is Graphics
Connector D is Sound
