Coyo5050
So without a RFID reader there is no point to trying to play the Nesica games?Someone pointed out the SF4 bug to me the other day. I'll have that fixed in the next release.I finally manage to have the fast io board running…..I have two questions if possible…It's normal that JVS games like sf4 for example, give me IO error if i use fast io instead of jvs?Actually with my multi, you can use FastIO to play JVS or FastIO games. As I've written a FastIO to JVS library, and from the few games I've tested, its actually brings JVS games up to the speed of FastIO due to blocking nature of functions the game has to call in order to poll the I/O.Well, thats a hard question
Because even a jvs, and even a fast io have limitations, as to what controller is plugged into them Meaning you could have a fast io, but with out the gc controller its not going to be very playable with said joystick setup
so I am going to assume you mean what stick and button games are playable on both
For JVS, You have the option to run nikos multi and boot all original None fast io games, Everything form Kof 98 To Kof Climax, to street fighter 4 arcade edition
You cannot run most nesica titles, however there is a few you can and those are battle Fanstisa, 3d cosplay mahjong, Samurai spirits sen , BBCS2 and kof climaxx nxl version both accept fio and jvs.
With JVS you are also able to run Nikos, JVS to keyboard code, thus turning your jvs device into a keyboard as seen by windows xp, this enables things like mame and other home-brew apps to control.
For Fast io, You can run every game designed to run on a fast io, so games such as ultra, nxl titles, ect including nikos multi however your not able to then go and play JVS titles, however
Corey has released a fast io to keyboard much like the one above, that enables you to homebrew up just about any software you would like
as to what id say is best, well personally a real rfid and fast io, because you can then play just bout everything, today was a jvs, is limited.
With your FastIO to Jvs, it could be possible to run some fast io games that give me 0203 IO Error?
The only FastIO game that is supported in v1.4 of my multi is BBCS2, all the other FastI/O games are Nesica games which give you that error because you do not have a RFID reader attached. When Taito retires NesicaXLive, I'll add support for the Nesica games into my multi. Including RFID emulation so you wont need an RFID reader.
