Hey every made a little tool for converting Fast IO inputs to Keyboard so you can use your fast io cards with nikos multi
To use it just rename this file to ttxjvs.exe and replace the same named file in the ttxmulti folder on nikos multi.
You will also need to copy over a iDmacDrv32.dll from one of the games or the system32 folder on nikos multi.
This is a precompiled version with the key inputs to mimic nikos jvs tool so its compatible for his menu.
https://mega.nz/#!4K4gWIAY!Ud4cX9vxQTV3emoVKEACpy9pJXRAp9X6VkWEw9gMZP8
This is the source code and can be edited similar to my update to nikos multi to change the key output so it could possible be used for PC games/MAME on the TTX. sorry but you are on your own though if you endeavor to do this.
In the future i might look at doing a Fast IO to JVS so playing the older TTXs game with fast io is possible.
https://github.com/fatal-bundy/FastIO2KB
Want to give a big shout out to niko as i used some of his code as it fitted perfectly with this as well and well i would have either written it the same or worse lol
ps.
@Darksoft @Mitsurugi-w would it be possible to get a TTXs tools sticky going to link to all the different TTX based tools/app.
ps.
