lupin3rd
(Moved here from the TTX2 forum, since I probably should have posted here instead.)
Having a helluva time with the TTX2. Full disclosure: I did not expect this thing to work at all, since it was an as-is YAJ purchase. I was purchasing it for the medal game, which didn't seem to be available anywhere else at time: Lupin the 3rd. Since I collect Lupin, I had to buy for that reason alone.
If you hate reading or verbosity, skip to the bottom where the TL;DR is.
Fast forward, the system arrives stateside. Tried to power it on just to see what the current state of affairs was. First thing I notice is that the fans are spinning up, then slowing down, and stopping. Then they spin up again, slow down, and stop. This cycle repeats several times, and finally the fans stay on and the system is in a "powered up" state. Black screen now, fans are on, JVS card has lights on. No POST messages, no GPU BIOS output, no beep codes, nada.
Next, I remove the lid. Oh god, the humanity! Bad caps popped open like popcorn everywhere! This explains what felt like a reboot loop, whereas the caps were depleting prematurely and causing reboots. There were 21 bad 1000uF 6.3V caps on this board. There should have been 22 bad ones, but it appears as though someone had already replaced one, as there was still signs of obvious flux on the back on the board as I discovered later. Metered out the CMOS battery, had a nice 3.03V on it.
I read the labels to ID the specific model and see what is supposed to be in the machine. Label says Model102A, and the hardware sticker says:
If experience has taught me anything, it's to check the power. I have an ATX breakout board that gives me voltage posts and a power on/off switch for ATX supplies. Hooked it up to that, turned the switch on and metered everything out. 5.04V, 3.34V, 11.8V, and -11.6V. Seems within spec, with no wild fluctuations. I didn't check for signs of AC ripple, but I think it was fine.
So, I figure I'll try the machine without its GPU and see if onboard worked, since that's easy to do and I didn't have 22 of the caps needed to fix them properly yet. No dice there. So then, I figured I'll try to stick the X1600Pro in another machine I have to make sure it isn't dead. No problem there, it fired right up in another machine. Fans working, etc.
Also tried some other known-working sticks of identical Hynix PC-5300U modules that I had on hand. No changes, but I didn't expect any since there were no POST beeps indicating a RAM issue.
Okay, caps are the only obvious thing left I can try. They show up, I install them. Things went very smoothly. I didn't have any issues getting them desoldered with my Hakko desoldering iron, temp was set to the lowest temp that would get the job done, so I wouldn't roast the board or any traces. Verified each cap as I went along, verifying component values and polarity at every step. Easy peasy.
TL;DR: After replacing the caps and reconnecting everything, I hold my breath and plug in the power cord. No fans. At all. No beep (although I didn't have this before, either). At first I thought I forgot to plug in the power cable because everything was so silent, but then I noticed that the JVS board had its LEDs on. Oh no! Something went very badly somewhere along the way.
I thought maybe I shorted something under the motherboard or didn't trim the cap legs well-enough. No issues on any of that. Looked for headers that were off-by-one, etc. Tried reseating everything.
If you've seen it before, what did you do? Do you have any ideas that I forgot to try or theories about what happened? I've replaced caps on PC motherboards several times over the years, and this one was just like all of those times, yet here I am.
Sorry for the big ask, but I like discussion, post-mortems, and since it's a brick as it is, I am not above anything at this time. If we deem it unfit to repair, I'll probably go ahead and dump the BIOS to potentially help others in the future, reuse the components in a TeknoParrot build and call it a day. I will attach some pictures of the work when I get home later this evening.
Images (Left to Right): Full view of board and bad caps, 1000uF cap testing at 27pF, game label, TTX2 model label:
- CPU: Cel 3.2Ghz
- MEM: 512MB
- GRA: X1300LE
