Fluorescent tube wiring Blast City
Bluechen
Germany
Sorry again me... I need to replace my old tube, so I decided to put a new LED. My problem is that I have three wires and no clue which wire goes where. Can someone help me ?
I have 1 white, 1 yellow, 1 white
That's an IEC C5 connector, as you face the 'socket' end of the cable which you are holding live is on the right, neutral left and earth top.
https://www.electronics2000.co.uk/pin-out/iec.php
For the blast side double check the schematic for it but i'm pretty certain black is live/hot and white is neutral. Although in this application it's going to a switch mode power supply for the LEDs so it isn't going to make any difference (you could fit a C7 connector without the earth pin and its reversible).
