This didn’t work for me. Error 00001
Could the CF imaging software make a difference?
I've been following the discussions about compatible CompactFlash cards and the various errors people have encountered with Garnet. I wanted to share a small observation that might be worth investigating.
I've successfully tested Garnet v0.88b using a SanDisk 8GB CompactFlash card. Interestingly, this appears to be quite the same card model used by another user who reported problems. The difference might not necessarily be the card itself. Could the software used to write the .img file to the CF card also be a factor?
Personally, I've been using
Raspberry Pi Imager to flash my images, and so far I've had no issues. I know other users are using different tools, such as HDD Raw Copy or Win32DiskImager, but I wonder whether these different imaging methods could potentially explain some of the reported inconsistencies.
My suggestion: If you've experienced errors with a CompactFlash card that is otherwise listed as compatible, why not try flashing Garnet again using Raspberry Pi Imager before ruling out the card? It would be interesting to compare results and see whether the imaging software actually makes a difference. I'm not claiming this is the cause, but I think it's another variable worth testing before we start compiling increasingly long lists of supposedly incompatible CF cards.
I'll attach pictures of my SanDisk 8GB card and my G-Net running Garnet v0.88b as proof of my working setup.
Perhaps we should be comparing not only CF card models, but also the tools used to flash them.
P.S. Also, 50 MB/s is seriously impressive when loading Garnet. It's so fast you barely have time to go for a piss!
