hyunatl
I have a vewlix L and the white plastic is very yellowed. I assume it's cigarette tar, anyone know how to get this stuff off? Thanks
If it's yellowing from age and uv, is there a paint that you'd recommend using?Gumption is the best at removing cigarette tar. You need something with a tiny bit of grit and a surfactant.
Also just be aware if it's yellowing of the plastic, it might be the bromine in the plastic and if that's what it is you're better off repainting
I've painted patent leather and used a sand free adhesion promoter , this works as well as it could. I'll probably use the same promoter and I found automotive grade acrylic epoxy that should be durable enough. I think youre right, its a good idea to practice and i will practice a little on some plexiglass to see if I like the gloss and just test out somethings first. Thanks for your suggestionDon't even bothering trying to paint these if it is your first time painting plastic. You will need to do considerable prep work on the pieces and use a quality adhesion promoter for lasting results. Practice on some scrap plastics first to get the hang of it and then come back to this. You will be happier.
