WTB - green cps2 b shell
Want To Buy
mR_CaESaR
Sydney, Australia
Anybody got a spare shell that can still be used with the 4 screws?
I've got a cracked shell and a broken screw holder and it's causing the board to not sit right causing some graphical glitches.. Once I take the b board out of the case, everything works perfectly fine.
Doesn't have to be green tbh... It's just the preferred :)
Do you have the clips to hold the A/B together? That sometimes fixes the problem you’re having.
Does the shell from your other B board work fine without the clips?
If not, it's most likely not the board at all, as you REALLY need to squeeze them together tight sometimes for there to be no graphical glitches. The clips fixed the problem. You can get those from tops-game.jp realtively cheaply.
My broken screw leg is on the bottom left of the cps2 b board (if you were to look at it with the label face you).
When I push it all the way, it gets there eventually, but because it's not properly screwed in, the plastic lifts.
I'll check out the clips thanks for the heads up
