Groove coaster english?
The Japanese version can be changed into English. It's just a registry edit.
Since the harddrive is ATA locked, you need to hot swap the drive to a Windows computer after booting.
In the Registry Editor, File, Load Hive
From the GC drive, under [C]:\Windows\System32\config choose SOFTWARE
Give it a name. You will see a new branch with that name under HKEY_LOCAL_MACHINE
Go to Software\Taito\TypeX, there is a binary value called Country
The contents of that value need to be "02 00 00 00"
Oh, and remember to unload the hive after you're done.
You can also do this with a USB updater file on a flash drive thats what I did. But I cant recall if you needed private network support to make it work or not.
