midwaydj
This is my second 9110 I received recently. Received this monitor dead, no neck glow, fan not spinning. I checked the b+ and it was low so I replaced the flyback and recapped the chassis. Powered on and got an image. Was adjusting the focus and the monitor shut down and the fan stopped. I'm suspecting the HOT TR15 may be bad as it's very hot and I broke the clip that secures it to the flyback cage when I removed it but it still has the insulator behind it. I tested TR15 and it's not shorted. Checked the b+ again and it is low again and the R105 30w resistor is hot again. BTW I'm a novice and just following Randy Fromm's 9000 flowchart. Any tips on how to replace those broken clips that secure the HOT to the flyback cage and what I might try next? The replacement flyback came from arcadepartsandrepair and I had to cut the flyback cage as recommended. I also read something about disabling the shut down circuit by lifting D10?
I also have another 9110 and tube that is working but the tube has burn in. Would there be any issue swapping the working chassis to the unburned tube? The tube with burn in is an RCA A63ADT10X05. The tube with no burn that I just temporarily tested with is an RCA A63ADT26X01. Both are 25 inch tubes, but the 9110 chassis seem to be slightly different board revisions. Just trying to be extra cautious thanks.
