AlxUnderBase
Here is for sale a used HAS Supergun V3.1
The package contain :
1 x HAS Supergun (V3.1) - The V3.1 uses the renowned "made in Japan" Hirose brand JAMMA connector with generous gold plating on contacts and general solid feel to it, however these connectors are known for their fragile connector ends which more than often just crack. The ends are cracked on my unit, too, but this doesn't affect the fit and alignment of the JAMMA edge at all
2 x Laser cut 4mm thick Acrylic Glass covers (for top & bottom) , a set of screws and spacers (unasambled)
1 x Power cable high quality 50cm long 16AWG to be used with a PSU + HAS supergun (included with HAS unit)
1 x CPS1 Kick Harness
1 x CPS2 Kick Harness
1 x HD15 Adapter PCB => With this adapter you can connect the HAS with the OSSC using a standard VGA cable (it helps with the Taito F3, which won't work with the OSSC when connected via the Scart). You can also use a VGA->BNC cable to connect it directly to PVM/BVM monitors. The adapter comes with a set of spacers)
1 x 8pin mini DIN to HD15 adapter PCB => With this adapter you can connect the HAS with the OSSC using a standard VGA cable (it helps with the Taito F3, which won't work with the OSSC when connected via the Scart). You can also use a VGA->BNC cable to connect it directly to PVM/BVM monitors. This adapter requires an 8pin mini DIN to 8pin mini DIN cable (pins must connect straight through end to end
1 x DB15 pair of dust caps for controller ports
1 x Retro Acess RGB Scart Cable (6ft option)
1 x Mean Well RT-125A PSU (unopened - unused)
1 x HAS key ring (bonus)
1 x Jamma Connector Key (bonus)
I want for this set 200€ + shipping costs (Europe - around 20€ , UK & USA around 25-30€)
PS : I also , can sell this set without the Retro-Acces RGB scart cable , Mean-Well PSU , Kick Harnesess with 150€ + shipping costs
paypal : friend & family only
HAS V3.1 Supergun Manual
Video :
View: https://youtu.be/uhhHMhRchJM
Video in action :
View: https://youtu.be/oepSD6V8sY4
Video in action :
View: https://youtu.be/ITKcnhIlx_M
Video in action :
View: https://youtu.be/PxrxI6EoV5U
Video in action :
View: https://youtu.be/Ni1cUDrqEts
Video in action : https://youtu.be/CjcqMxRXjUo
Video :
Video in action :
Video in action :
Video in action :
Video in action :
