Hat Trick Hero 95 sound issue
raidenmaniac1
Reno NV
Is there any issue with Hat Trick Hero 95's rom dump?
I am using roll up pack from 8-25-2017.
The issue is that do not hear the crowd cheering up while playing a game; I only hear the players kicking into the ball.
I did setup the game with default factory setting in the setup menu after launching the game to prevent
any missconfiguration from using E2 settings from a different previous game.
Is anyone else noticing this issue ?
looping @Asure into the thread. It may be a rom merging thing. Did you try the other Hat Trick versions? Worked well?
I took a look at my SD image and the versions i built, but Hat Trick Hero 95 is not a folder.
This would indicate i didn't modify those roms for some reason, so i didn't test/play extensively on that game.
I did make a set for Powergoal (pwrgoal) which is the same game, do you have crowd sounds on that one?
My bad, I actually hear the crowd sounds now on Hat Trick hero 95. I had the "cheer" option turned off. :]
Sorry for the false alarm
What is the actual screen name for Power Goal ? I don't see it on the LCD screen when scanning through the list
