Help needed - Monitor connections/pinouts
bagheera369
DFW - TX - USA
Ok...I did some searching, and am not finding answers for these two, as I'm building my TPG adapters.
Sanwa 27z21c - I have the 12p connector, but the wires are not self-evident for the RGB connections, and I need the pinout for this connector, please.
Nanao MS8 26su - I'm trying to figure out what connection the small 6pin connector on the chassis uses for RGBGHV. I know it's not JST PH, as I tried that already.
If anyone can offer up a hand here, i'd be eternally grateful....I'm very ready to get these things tested, and then out of my garage.
What 12 pin connector for the sanwa? The one I have here and the schematic say it uses a 6 pin JST NH for video input.
For the MS8 and many other monitors, the RGB input connector is JST EH series.
Thank you for the info, sincerely.
I was looking for the pinout of the 12pin, in this picture, because I wasn't in a place where I could see that it was connected to that NH connector on the chassis.
Now that I have that, hopefully it's screen-printed, or I can trace it back, and figure out the 12pin.
I need it, because I'm building an adapter that will feed in power as well, rather than have to wire it separately....and I already have the connector and pins for it.
I didn't know about the EH series connector....the ones on my PFX are PH...so that adapter is built already.
Thank you again...this definitely helps.
Oh yes this is the connector used on American Namco cabinets. Found this pinout online, looks like your connector is rotated 180 degrees but should match up. Verify first though.
The JST EH pinout is the same on MS8, MS9, Toshiba PF, Sanwa E31S, Toei L292 and many more btw.
