Hi all,
I’m hoping someone can help me out!
I’m having issues with my Sanwa 29E31S with its tri-sync chassis, which I believe to be a Rodotron 666a.
I had an outstanding previous issue with the vertical height with 15KHz sources being too tall, but it was otherwise working until today.
I was running Mars Matrix on the cab, when picture suddenly flickered for a split second, then went black. The relay on the chassis began to tick, about once a second.
Now that’s all it does, completely blank screen, relay ticking approximately every second. I’ve tried both 15KHz and 31KHz input sources, and the result is the same, although I think the frequency of the relay ticks is slightly quicker with 31KHz.
Here’s a video where the ticking of the relay can be heard (you may need to turn up the volume a touch):
The monitor makes a hum and a feint hiss sound between each tick, nothing that sounds unusual, but it’s like it’s trying to ‘start up’, but failing, then trying again, over and over.
Tick, hum, hiss, tick. Pause.
Tick, hum, hiss, tick. Pause...
Does anyone have any advice? Is this a chassis issue, or is the tube screwed? I’m hoping the former rather than the latter. I’m fine with game boards, but when it comes to monitors, I’m pretty clueless.
I need to get it up and running, since my cabinet also serves as my main board testing rig when tinkering for our CPS2 and CPS3 projects and repairs, as well as being used by myself and my kids for playing our games!
