Hello everyone!
I need your help with a 4-slot Neo Geo MVS—specifically, a NEO-MVH MV4F model.
I am attempting to connect a replacement for the original MV-ELA module to the board's 8-pin "EL" connector. Before doing so, I began checking the voltages and encountered something I cannot quite make sense of.
The issue: When measuring with a multimeter (set to DC) while the board is powered on—and with the EL connector completely disconnected—I get approximately 17.5 V between pin 1 and pin 8.
The pinout I am using for the EL connector is as follows:
Pin 1: VCC (+5 V, according to the information I have)
Pin 2: Clock
Pin 3: Data 0
Pin 4: Data 1
Pin 5: Data 2
Pin 6: Data 3
Pin 7: NC
Pin 8: GND
What puzzles me is that I also measured approximately 17.5 V between pins 1 and 13 of the "MV-MAIN to MV-LED" connector, which corresponds to the outputs for the credit display panel.
Nevertheless, the original credit display panel works perfectly when connected to the board. Both measurements were taken with the connectors empty, with no devices attached.
Other checks:
With the board completely powered off and disconnected from the power supply, I measured the resistance between pins 1 and 8 of the EL connector.
The multimeter initially shows a different value, eventually stabilizing at approximately 437 Ω. If I reverse the test leads, I get virtually the same result.
I am not yet sure if this is normal—due to the components connected internally—or if it might indicate a problem. The MVS board itself functions correctly in terms of gameplay and general operation. I discovered the issue while investigating the power supply for the EL connector.
Here is what I would like to know:
Is it normal to measure approximately 17.5 V between pins 1 and 8 of the EL connector when it is disconnected?
Could this be a floating voltage, or perhaps an auxiliary power source that I am misinterpreting?
Does anyone have the electrical schematic for the NEO-MVH MV4F and could they tell me how this connector is powered?
Which components should I check to locate the source of this voltage?
Could there be differences between revisions of the MV4F that might affect this circuit?
I don’t have much experience with electronics, so I am trying to take it one step at a time and avoid connecting anything until I understand what is happening. If anyone has experience repairing these boards or is familiar with the EL circuit in four-slot MVS systems, I would greatly appreciate any guidance.
I can provide photographs of the board, the connectors, and the measurements I have taken.
Thank you very much in advance!
Pin 2: Clock
Pin 3: Data 0
Pin 4: Data 1
Pin 5: Data 2
Pin 6: Data 3
Pin 7: NC
Pin 8: GND
Other checks:
