So I have a Sigma supergun because it was pretty cheap ($140~ I think) but was lacking some pretty important parts, namely the proprietary loom and sticks, which use annoying connectors but I'm fine with I guess since it would've been 3x more with them. My main question is, this box uses 13 pin DIN connectors for the sticks. Provided I find the pinout, can I just wire a couple male connectors to a db-15 connector, and then plug in a UD decoder into that, and then plug in a USB stick to that, without the need for a 13 pin DIN --> db-15 decoder? So basically: din connectors —> (screw terminal)male db-15 connector —> UD jamma decoder —> usb stick. Is such a thing even possible?
I have another question but I haven't quite done my bare minimum of research so any help for my issue here will be greatly appreciated.
