i960 assembly
tangodownNZ
New Zealand
Does anybody know of an assembler for an i960kb cpu. I am trying to write instructions for Daytona USA.
I tried "GNU binutils supports the i960" using wsl on my pc. But I just get errors as it is no longer supported.
Any help would be great. Thanks
So you have a few options here:
Be warned that assembling a Model2 game from a disassembly is going to take a lot of trial and error before you can get something bootable. You will need to clean up a lot of code and make sure you have correct MEMA/MEMB displacements.
Thank you @biggestsonicfan
I was going to install Windows 95 onto an old machine because I read that CTOOLS 6.0 will not run on a modern Windows 11 system. Or run it on a virtual machine, which I don't want to do. Can you please advise further, thank you.
I am using ida pro to look at the instructions and bytes. I search for the instruction I need and get the bytes. I just could not find cmpibg r4 , r5 but I found it now. But no doubt I will get stuck again. That is why I want to start looking at CTOOLS. Thanks again
I use CTOOLS 6.0 just fine on Windows 11! If you have any troubleshooting just ask away here!
GCC 2.95.3: Older versions of GCC supported the i960 architecture. Modern efforts to support the i960 SBC (Single Board Computer) use GCC 2.95.3 with binutils 2.21.1 in Docker environments.
Here is a link to CTOOLS documentation
https://intel-vintage-developer.eu5.org/DESIGN/I960/MANUALS/485544.HTM
https://datasheets.chipdb.org/Intel/80960/manuals/65123003.PDF
Oh that's true, I forgot about the git repo of modern single board i960 system. I haven't used a docker system to build 80960 assembly so your mileage may vary.
