IGS PGM Cart PCB Scans (And Projects)
Is this much of a label color difference common (Dragon World 2)? :)
Ah sun faded the bottom one :) I think the cart color difference stands out more. I have seen the solid red ones on eBay more lately.
Yeah its common.. i have a heap of both.... BUT the "Solid" RED cart is more common. The only difference is the white one has a newer revision of the program rom...
Update,
Added more PCB scans to my site!
Work has started on building a huge new website.... with a new domain. But it still needs alot of work to finish it.....
"BATCH 3" Of my Pre-Modded PGM Motherboards are now open for orders!! There is only a few spots left. Units should be ready by DEC 2020.
Message me if you are keen / want more info, Or contact me on Discord.
Tim.
Took some scans of my Oriental Legend (China region) cart. Sadly my scanner doesn't really like 'depth' on the component sides!
Top PCB NO-0134-2 (doesn't have the large socketed EPROMs as on your current pcb scan)
U4 code = CW U4?
U12 code = ?
Bottom PCB NO-0135
(I have the full 300dpi versions.. these are just shrunk for the forum!)
Yep sadly I only have a little scanner here. By all means I can take high res digital photos that are well lit of the component sides if you're still interested in these cart pcbs.
U4 code = CW U4?
U12 code = ?
Bottom PCB NO-0135
I'm interested about the full 300dpi scans because the GFX ROMs from your cart have different labels ROMs regular oriental Legend
version. It probably needs to be dumped...
It doesn't appear to be particularly fancy really (not like others I have that look like mods and conversions internally).
GFX are on the base PCB I take it?
