I've been working on these for a while but I never got around to writing it up - I learned a lot from this one
So I have some Minigun Supergun 2.5 Advanced that I made thanks to FrankFJS awesome work, project log for that is here
https://www.arcade-projects.com/thr...d-the-projects-that-others-have-shared.17296/
And I have a bunch of pads and various hacked-up controllers (including the worlds most expensive icade with all Sanwa parts) for testing, but I really wanted to use my "good stuff" like my Sega HSS-0136 with it as well.
So clearly the thing to do was make some Saturn2Neo adaptors.
I based my work on Arthimus guthub code here
https://github.com/Arthrimus/Saturn_Controller_Demux
and gerbers here
https://oshpark.com/shared_projects/wuq1ltGg
There is a slightly more modern revision here that has removed some SMD resistors, added an indicator LED, and removed the programing jumper, next time I might give that one a go
https://www.arcade-projects.com/threads/sega-saturn-to-neo-geo-controller-adapters.8858/
This project is actually nearly finished, so I'll try to remember all the stuff I did and post it here
I ordered all of the boards off PCBway - I was woried that they might not cut the retention clip into the PCB correctly because their online tool doesnt show it, but it was in the drill file, and in the gerber, and they did it perfectly. I also got a bunch of other boards for other stuff I'm working on (129x clone card and etc) I really dont like the solder mask from other PCB manufacturers OSHpark, scratches too easily, so I got a bunch of different colors to see if there was any improvement.
I also got the top "lid" to provide mechanical strain releif for the saturn port, PCBway count this as a seperate PCB whihc doubled the manufacturing costs - a promising start
All the standard parts came from Digikey because they ship to NZ for free (for orders over $NZ100 only) and because the are good brands with a good supply chain - RS components had some fake stuff comingled recently.
Some of the parts for this were ONLY available off Aliexpress (female saturn ports) so I bought these ones - Unfortunately for the environment it's not possible to just buy the port, I had to buy the extention cable and cut the female port end off.
The quality was much better than I expected for three dollars per unit - delivery took 25 days :-/ Getting these things ready to be installed was very labor intensive - I'll do a seperate post on them later.
https://www.aliexpress.com/item/1005002668796484.html
and gerbers here
