Installation of Joysticks to metal plate
The LS-32 uses the 50mm screw spacing (Seimitsu calls this P=50), so you'd need a plate with that same 50mm spacing, and then you'd need the plate to match your panel's mounts. Your measurements appear to be off (the calipers don't look to be centred on the posts), but it looks like 65mm on one axis, which matches the Vewlix spacing. I dunno what the 72mm is all about, maybe someone else can point to a 65x72mm arrangement.
Seimitsu makes an 'all in one' with a Vewlix pattern, but while that'll mount a Seimitsu P=50 mech, it will only match two of the posts on your panel.
https://www.cqbarcade.com/products/...e-mounting-plate?_pos=33&_sid=50915f0fa&_ss=r
It'd be very easy to 3Dprint a plate to fit your panel and a P=50 stick, but you'll want to be precise with the measurements of those posts. Try measuring from the outside of both posts, and subtract the diameter of one post to get the accurate spacing.
Very, very easy:
This has holes for P=50, P=40, and Sanwa 4- and 2-hole mounts. Assuming the 65x72 spacing is correct. Let me know if it's not and I will revise it.
Got the prints today and it worked like a charm, thank you good man!
