nnap
would be great, put me on the list for one.
Maybe replace the ROMs with flash chips and a way to rewrite them in place?Just to temper expectations here, the jamma board contains the program roms and sound roms on Namco system 11 and 12 so i don’t know how the heck you’d get around that for a multi
Easy...Just to temper expectations here, the jamma board contains the program roms and sound roms on Namco system 11 and 12 so i don’t know how the heck you’d get around that for a multi
Nope!Maybe replace the ROMs with flash chips and a way to rewrite them in place?
That would work too and have no load times. Assuming suitable capacity chip are available.Replace the ROMs with larger chips that contain ALL the program/sound data for every S11/12 game and bank switch via dips before powering up/booting.
It might require some creativity. Like soldering a flat flex cable (FFC) to the ROM pads. Then the FFC would plug into a daughter board with the flash ROMs and support logic.![]()
Those
Yup just what I was thinking, a daughter board packed with all the game data and bank switching dips.Like soldering a flat flex cable (FFC) to the ROM pads. Then the FFC would plug into a daughter board with the flash ROMs and support logic.
Yes, what I proposed would require higher soldering skill and specialized tools compared to many of the (nearly) plug-n-play multi kits found around here.That’s some super fine pitch, I don’t see the average or even above average person being able to a) remove those cleanly or more so b) solder anything to that reliably.
But hey I won’t put it past DS to figure something out, just letting the folks chiming in here that it’s got this extra degree of difficulty involved.
maybe it would end up as a multi where pro modders end up doing the work, like some hdmi mods
Its only slightly smaller than the spacing on MAV N64, and to assist with the solder job you get this adapter...That’s some super fine pitch, I don’t see the average or even above average person being able to a) remove those cleanly or more so b) solder anything to that reliably.
Yea its super small, but I bet a bath in liquid flux with some drag action would attach it.These are .5mm
