Is a A48LRH93X tube a good donor for K7000?
Derick2k
NYC, USA
Got a 19" TV with this tube in it, trying to see if its a drop in to use with a K7000. Looks like a thin neck, so its a CR-31??
Way to test the yoke would be red/blue - yellow/brown??
Found a post from Ken way back, looks like the equivalent to a A48JLL90X so it should be a drop in replacement no yoke swap needed, but will take readings regardless.
Now to see if my K7000 has a matching neckboard.
Keep us posted on your results. I have also been getting prepared for the mini cute with a few K7000s on an A48JLL40X (CR-31) and an A48KRD82X (CR-23).
Been running into THIS ISSUE on both tubes using multiple chassis.
Oh man, I hope some of the crt experts that have done tube swaps chime in on what could be the cause.
I have several options going right now the Cute repro:
K7000 with this tube swap
or the following with a scaler
Dell 2001FP Ultrasharp 20" LCD
Dell P991 or P992 crt monitor
If the tubeswap dont work, will just go with the lcd and call it a day
Is the 2001FP known to fit in the Mini Cute repros?
The folks at KLOV straightened me out. I had the dag wire going to the wrong ground. Nice clean image (except for some convergence) on my donor tube now.
Oh, sweetness! Ill report when I do some testing, Im considering picking up another of these to have a spare just in case
