Jamma Arcade Kit for Vewlix
Crown Arcade Shop
Seoul, KR
I've built a JAMMA Arcade board to work with the Vewlix Dia.
At this point, I've only made a sample.
Interface board has two DB15 connectors with Taito G connector. I used the unused pin 9 in DB15 to put in the SERVICE and TEST buttons.
In the production version, I'll add the button remapping and auto fire function, and support harness for pandora box.
The board for JAMMA is suitable for GBSC & OSSC. I also used an audio amp to work with RCA level amp.
In the production version, I'm going to change the layout to use a wider DB15 cable. The connector on the right are for the kick harness.
