JAMMA controls splitter question
BroadwayJose
Las Vegas, NV USA
@RGB a question about this product:
https://rgbslab.com/products/jamma-controls-splitter
Purchased one a while back but only now getting around to trying it out. For the KICKS IN section, it appears to accept a CPS2 style kick harness female lead. Does that mean I would need to come up with a harness that has the same female lead on both sides if I were to connect it to a CPS2 board or anything else which utilizes the same style of connection for the extra buttons?
Are there pre-built harnesses available for purchase from you or elsewhere?
KICKS IN connector takes buttons 4-5 from your cabinet, and KICKS OUT must connect to the PCB game. The kick harness between the splitter and the PCB game is the same as for the HAS/RECO, and I believe that Minigun and some other superguns use the same pinout and connector, too. I offer CPS-1, CPS-2, and ST-V kick harnesses.
Edit: Looks like I've only got CPS-2 kick harnesses in stock.
Thanks @RGB. I assumed this was the expected method but the terminology was a bit confusing for each section on the splitter board considering the extra button signals were coming into the splitter from a CPS2/etc board rather than going out but maybe it's just my weird way of looking at it.
Ended up borrowing a CPS2 harness from my HAS setup and it all worked as expected for the extra buttons. Great product - much appreciated!
  • Love
Reactions: RGB
