@JohnRambo'sKnife also felt some lag on his
Thank you ! I have version 1.6On the jammafier, you can see the JVS update frequency - lag will then be 1000/frequency=milliseconds. For context, 1 frame takes about 16.7ms, you will have (way) less than this.
I/O board also comes into play a bit, but the jammafier will not be the limiting factor.
i see. is this easy to "change" to another model? wich model?So most likely the: Sega 837-13551, this device is considered to be one of the slower IOs. I.e the time it takes from request to response from the IO.
like this one?From some light googling you should be able to swap to: 837-14572 but I am not an expert on this cabinet![]()
I thinkThis site lists the various SEGA IOs, I would compare the connections to determine if it's a drop-in replacement.
https://wiki.arcadeotaku.com/w/JVS
In the process of converting all my NNCs to Jamma with the TDIO to run JVS.I think
SEGA I/O BOARD TYPE 3 : 837-14572is 100% compatible so I'll buy one to upgrade and let you know if it improves
Maybe @JohnRambo'sKnife and @Tailsnic Retroworks are interested in this too
